I’ve been using a heatsink case for my other Pi 4’s, which give really good passive cooling. But, it’s impossible to put a HAT on top without using spacers to stabilise the HAT.
I’ve just got another Pi 4, using the Coupe case and heatsink. I plan on putting my Hyperpixel on top, with the provided spacers. Is this is a good idea?
How much heat can the Hyperixel take before being damaged?
edit: I can’t use the fan shim, as the Hyperpixel uses all GPIO pins.
Just to say that I’m not having any heat issues with the Hyperpixel display on top of the Coupe case + heatsink, at least with my use case. There’s plenty of space around the sides for airflow.
