Hi, two days ago received from your company the ordered Adafruit ESP32-S3 TFT (verA).
Using Arduino IDE v2.3.4. with latest updates. Created a sketch to show data from a I2C connected MCP9808 sensor (connected via the Stemma QT/Qwiic connector). Works OK when powered from PC USB or a 3.7V battery. However does not work from an external 5V DC Power source. I have also an Adafruit Feather ESP32-S2 TFT flashed with Circuitpython. That board runs OK on that same external 5V DC Power source.
In the sketch I have the following commands:
// turn on the TFT / I2C power supply
pinMode(TFT_I2C_POWER, OUTPUT);
digitalWrite(TFT_I2C_POWER, HIGH);
Using a USB Volt / Ampère meter device, I saw that on the PC USB the Voltage was: 5.157V, and the current drawn: 0.062A. I saw that on the external power supply, the Voltage was:: 5.033V and the current drawn: 0.062A
I checked for possible solder issues. Re-touched with the solder-iron various Pins that I assumed to be important to check.
Any ideas to solve this problem?
