Analogue stick always down
I have the issue that the stick Is always moving down. Not had time to use it since getting it. Now, Even when I remove the analogue stick from the 32blit it still moves down.
Is the board faulty or the analogue stick?
I have exactly the same issue, did you ever get a solution to this?
Only solution i think was to replace it. I contacted support@pimoroni.co. They send out a replacement stick. I installed it and now working fine.
Hello,
I have the same problem :-( . i have send a email to pimoroni.
i wait ;
They are the same part as Nintendo switch thumb sticks if you want to replace it yourself (be careful with that ribbon cable though!)
