Have used the Badger successfully, some time back. Running on Win-10, September update.
Started with the Automation Mini, but I don’t get the “>>>” in the shell window, and when trying to run the example I get the error attached. COM5 is only present in Device Manager when the Automation is plugged in. Have uploaded the firmware pimoroni-picow-v1.19.8-micropython.uf2. Am I missing something obvious? Tried running Thonny as Admin, but no difference.
Thonny is looking at the wrong port number. You need to manually reconfigure it and select the correct port. Mine switches around depending on what Pico Tufty etc I have plugged in. Even when I use the same USB port.
Resolved - it was a COM5 issue.
Long story: I have Franson GpsGate installed which I have set up a long time ago to use COM5 as a virtual COM port to which other programs can connect tot display or analyse GPS data. This virtual COM port does /not/ show in the device manager with Franson active, even when a client program is connected to Franson. So I changed Franson to COM4 and all is OK.
Thanks for your patience and suggestions
