Breakout Garden Script
Hi
I have a Breakout Garden on a Pi Zero. I did run the install script and solved some problems with smbus and now I am getting the following error. A search of the forum suggest that the script should install the necessary libraries. Any help appreciated
pi@raspberrypi:~ cd breakout-garden-master pi@raspberrypi:~/breakout-garden-master sudo ./install.sh
Breakout Garden: Installer. (1 breakout(s) found)
bme680 weather sensor: Error!
./install.sh: line 175: cd: bme680-python: No such file or directory
Installing 1 module(s). Enter to continue (Ctrl+C to cancel)…
Errors occured during install. For more info see /tmp/breakout-garden/install.log
Try running curl https://get.pimoroni.com/bme680 | bash and see if that helps.
I have a couple of BME680’s in use, I don’t have any of the breakout garden hats etc though.
