Suddenly I cannot enable my Hyperpixel (not 4) display. Have not used it for a while. Installed it on a RPI 3B, with Bullseye 32 bit and rand the install script. All went well, but the display does not come on. The HDMI does work though. Same if I take the HDMI cable out.
Linux raspberrypi 5.15.56-v7+ #1575 SMP Fri Jul 22 20:28:11 BST 2022 armv7l GNU/Linux
The hyperpixel services statuses are (see below) and there is a touch error, and further down my config.txt:
pi@raspberrypi:/boot $ sudo systemctl status hyperpixel-init
● hyperpixel-init.service - Hyperpixel LCD Display Initialization
Loaded: loaded (/lib/systemd/system/hyperpixel-init.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Sat 2022-08-20 15:06:23 CEST; 28min ago
Main PID: 275 (code=exited, status=0/SUCCESS)
CPU: 130ms
Aug 20 15:06:22 raspberrypi systemd[1]: Starting Hyperpixel LCD Display Initialization...
Aug 20 15:06:23 raspberrypi systemd[1]: hyperpixel-init.service: Succeeded.
Aug 20 15:06:23 raspberrypi systemd[1]: Finished Hyperpixel LCD Display Initialization.
pi@raspberrypi:/boot $ sudo systemctl status hyperpixel-touch
● hyperpixel-touch.service - Hyperpixel LCD Touch Screen Driver Daemon
Loaded: loaded (/lib/systemd/system/hyperpixel-touch.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2022-08-20 15:06:27 CEST; 28min ago
CPU: 236ms
Aug 20 15:06:27 raspberrypi systemd[1]: hyperpixel-touch.service: Scheduled restart job, restart counter is at 5.
Aug 20 15:06:27 raspberrypi systemd[1]: Stopped Hyperpixel LCD Touch Screen Driver Daemon.
Aug 20 15:06:27 raspberrypi systemd[1]: hyperpixel-touch.service: Start request repeated too quickly.
Aug 20 15:06:27 raspberrypi systemd[1]: hyperpixel-touch.service: Failed with result 'exit-code'.
Aug 20 15:06:27 raspberrypi systemd[1]: Failed to start Hyperpixel LCD Touch Screen Driver Daemon.
My config.txt:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Disable compensation for displays with overscan
disable_overscan=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
[pi4]
# Run as fast as firmware / board allows
arm_boost=1
[all]
# HyperPixel LCD Settings
dtoverlay=hyperpixel
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=800
framebuffer_height=480
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x6f016
display_rotate=2
hdmi_timings=800 0 50 20 50 480 1 3 2 3 0 0 0 60 0 32000000 6
# Use a basic GPIO backlight driver with on/off support
dtoverlay=hyperpixel-gpio-backlight
