I have a test Raspberry Pi that I use for new components
I need to replace on old Display-O-Tron so have purchased this Hyperpixel
I have inserted the Hyperpixel and all the pins are aligned and I have good contact
I use Raspberry Pi Imager v1.8.5 with the following settings
Device: Raspberry Pi 3
Operating System Raspberry Pi OS (64 Bit) with the Respberry Pi Desktop (Recommnded) released 2024-07-04
Storage: 16 Gb Card
Settings hostname pi96
Username/Password pi/rapsberry
Wireless LAN (local config)
Locale gb
Enable SSH
I insert the card and plug in a Raspberry Pi Power supply
There is a slight brightness on the screen as power is applied which implies it is getting power
(Similar to a cscreen with power but no signal)
I do ‘ssh pi@192.168.1.147’ and add the ssh key to the authorized keys file
I then do
- mkdir Pimoroni
- cd Pimoroni
- git clone GitHub - pimoroni/hyperpixel4: Driver for the Pimoroni HyperPixel 4.0" Touchscreen Display -b pi3
- cd hyperpixel4/
- sudo ./install.sh
Notice: building hyperpixel4.dtbo
Created symlink /etc/systemd/system/multi-user.target.wants/hyperpixel4-init.service → /etc/systemd/system/hyperpixel4-init.service.
Installed: /usr/bin/hyperpixel4-init
Installed: /etc/systemd/system/hyperpixel4-init.service
Installed: /usr/bin/hyperpixel4-rotate
Installed: /boot/overlays/hyperpixel4.dtbo
Config: Added dtoverlay=hyperpixel4 to /boot/config.txt
Config: Added overscan_left=0 to /boot/config.txt
Config: Added overscan_right=0 to /boot/config.txt
Config: Added overscan_top=0 to /boot/config.txt
Config: Added overscan_bottom=0 to /boot/config.txt
Config: Added enable_dpi_lcd=1 to /boot/config.txt
Config: Added display_default_lcd=1 to /boot/config.txt
Config: Added display_rotate=0 to /boot/config.txt
Config: Added dpi_group=2 to /boot/config.txt
Config: Added dpi_mode=87 to /boot/config.txt
Config: Added dpi_output_format=0x7f216 to /boot/config.txt
Config: Added hdmi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6 to /boot/config.txt
Before rebooting, use ‘hyperpixel4-rotate left/right/normal/inverted’ to rotate your display!
left - Landscape, power/HDMI on bottom
right - Landscape, power/HDMI on top
normal - Portrait, USB ports on top
inverted - Portrait, USB ports on bottom
- sudo hyperpixel4-rotate left
Rotating display
Setting matrix: 0 -1 1 1 0 0
Authorization required, but no authorization protocol specified
Unable to connect to X server
Saving touch settings to /etc/udev/rules.d/98-hyperpixel4-calibration.rules
Please reboot for changes to take effect!
- sudo reboot
After it reboots I can still ssh to it
If I shut it down and then plug in a HDMI cable ( the Hyperpixel is still on board) then I get the standard Desktop on the screen but still nothing on the Hyperpixel
Any suggestions on what is going wrong?
David
