Connect Inky Impression 7.3" to Jetson Orin Nano
Hello, I just got the 2025 edition of the Inky Impression 7.3” eInk display. I have a question about interfacing this display to a Jetson Orin Nano running Jetpack 6.2. My question is as long as I am enabling SPI0 or SPI1 via Jetson-IO and connecting respective pins from the 40 pin header to the display, it should be straightforward to work, right? Thank you.
I think this was answered over on the Discord, so the answer sadly remains the same - in principle it should work, but you’ll have to do some tweaking with the Pimoroni library / installer, which does checks that it’s being run on a supported OS.
