I’ve bought a second-hand Picade off someone, he failed to get it working - I do know my Linux (…but not the emulators). I’ve run the many updates required as of today, but I’m struggling too, perhaps he’s broken the distro on the SD card.
I have an RPi 4 Model B in mine, all hardware works (speakers, joystick and front buttons etc) but no joy even getting it to run a single game, I appreicate that the front end runs other back-ends. I have plenty of ROMs and I’m used to using MAME on a PC.
Is there an SD card image I can download, that has everything “in place”, so I can just drop ROM images into the appropriate folders and then, do a re-scan and play them. I’ve wasted over half a day now on the existing installation (likely broken), and I’m at my wit’s end with this - something that was supposed to be a quick diversion for a bit of fun, has ended up taking way more time than I’d anticipated.
Alternatively, if there’s a distro that I can get, which I can run a few apt-get things on, and get it working, I’m fine with that also. Please bear in mind, it’s now mid-August 2025 - I don’t want “this should work” - does anyone have anything that actually works, right now, or an SD card image? Mine’s the Picade with the diagonal rainbow stripes over the joystick port.
Honestly, without knowing exactly which Picade you have, it’s kind of hard to give you a definitive “here’s an image that will definitely work”, and your “I don’t want suggestions, just certainties” makes me aware that I’m just wasting my time, but…
Hel’s latest and greatest “Setting Up Picade” (Setting Up Picade) probably covers your version - the fact you’re running a 4B in it suggests it’s probably not an original, at least - and if nothing else it would give you a “known state” instead of whatever random broken installation you currently think you have.
But identifying the Picade will make more certain answers more possible - even just a screen size and button count? :)
Thank you so much! I’ll do a fresh installation and then go from there following these instructions - I was just frustrated that I have good hardware, but bad software installed, and being a single Dad, I don’t have much time on my hands.
It’s tricky getting a keyboard and mouse plugged in that don’t draw much current - almost everything I have for my son, has LEDs and other things on it, that make the Pi reboot as soon as anything “demanding” happens. I do have an old awful pair of HP keyboard and mouse that will likely get the trick done. From there, I’ll be fine.
P.S. If you’re in the UK, a visit to “Arcade Club” is well worth it, Bury is my closest one, and it’s awesome - lots of arcade machines, with cheap food, and beer!
