Can somebody tell my if the GPIO Ribbon Cable (CAB0505) will work with the Pi Zero W?
I’m intending to use the ribbon cable to connect another device to the Pi Zero W. I’ve already got one of the GPIO Hammer Header kits (PIM296), so the ribbon should connect to the Pi Zero W fine. The connection on the device I’m looking to hook it up to also has pins ready to connect (It’s a ZX Spectrum Next if you were wondering). The main reason I ask is that I see in the details of the ribbon that it’s not compatible with some models of Pi. There is no mention of the Pi Zero compatibility in the description, hence I check.
Thank you.
