You shouldn’t need to change an IP address, but it might tell you which port to use when it fires up.
Do you see something like:
* Running on http://0.0.0.0:5000/
This 0.0.0.0 iP address means it should be accessible both locally and remotely on port 5000 and be bound to all the IPs your Pi has available ( wlan/ethernet ). But don’t enter the IP 0.0.0.0 since that wont get you far. If you’re on your Pi, try:
http://127.0.0.1:5000
If you’re trying to get to it remotely, use ifconfig to find your Pi’s address.
Aha! This is definitely one for me to remember. It’s always things like this that I’d never think about, but which are, in retrospect, very obviously confusing!
For system stats on my server i use PHPSYSINFO http://phpsysinfo.github.io/phpsysinfo/
Its very easy to install and you can view and modify the config to display exactly whats going on with your setup.
