Hello from Athens Greece.
Tonight i finished building the Picade 10inch with Raspberry PI 3b+.
When i turn it on it always saying that the hdmi has no signal.
What should i do?
Also i tried another HDMI cable but nothing again.
Please help me!!
Try adding hdmi_force_hotplug=1 to your config.txt file.
run the following from command line to edit that file.
sudo nano /boot/config.txt
Thank you very much! It worked!
Now it doesnt recognise my controls.
What should i do?
That I don’t know, I don’t own a Picade, and don’t game on my Pi.
I guess you will have fixed it, but if not, I will tell you that you have to install the X HAT software to make it work properly.
And with which command will i do that?
You have to be connected to the internet.
To run the installer, open a terminal and type:
curl https://get.pimoroni.com/picadehat | bash
You’ll need to reboot once the installation is complete, if it doesn’t prompt you to do so.
