It is not really a project. I just find it good, not very difficult to setup, seems nobody share the same thing here before, I come to fill the gap.
I have my PiZeroW running headless, only power-line in, a 32G music usbkey (with the OTG Converter Shim), line out from pHatDAC to a mini-amp. I use my Android phone to select what music to play.
(Planning to use Blinkt as VU meter, TouchpHat to poweroff and maybe something else. Meanwhile, I ssh in to poweroff.)
To Install MPD. (I use raspbian, mpd installed is ver 0.19.1-1.1 and it works fine for me.)
sudo apt-get install mpd
Make sure you do NOT run mpd as a system daemon which will bring you tons of file permission problems. So,
sudo systemctl stop mpd
sudo systemctl disable mpd
sudo systemctl stop mpd.socket
sudo systemctl disable mpd.socket
Make a new home for mpd settings
cd ~
mkdir -p .config/mpd/playlists
cp /usr/share/doc/mpd/examples/mpdconf.example.gz ~/.config/mpd/.
cd .config/mpd
gunzip mpdconf.example.gz
You should now have a file mpdconf.example there, edit it so that it has
music_directory "/media/pi/32GKEY/musicbox" playlist_directory "~/.config/mpd/playlists" db_file "~/.config/mpd/database" log_file "~/.config/mpd/log" pid_file "~/.config/mpd/pid" auto_update "yes" audio_output { type "alsa" name "My ALSA Device" device "hw:0,0" mixer_type "software" }
I run the following command to filter out comments and blank lines for easy checking
cat mpdconf.example | grep -v “^#|^$”
Your usbkey should be auto mounted to /media/pi/keyLabel/nameYouGave
To autostart mpd after boot, edit ~/.profile and append the following line
mpd ~/.config/mpd/mpdconf.example
My headless pi boot to cli, less overhead and better performance, but you can’t use other autostart methods that depends on X.
Reboot, then
ps aux | grep mpd
to see if your mpd command is running. You may want to check out ~/.config/mpd/log too.
On Android, install MPDroid, input the ip addr of your pi and port 6600. That’s it, enjoy.
Reference
https://www.lesbonscomptes.com/pages/raspmpd.html
https://wiki.archlinux.org/index.php/Music_Player_Daemon
