Sorry if this is a repeat question but I have found conflicting information online…
Can the HyperPixel 4 square (non-touch) display be used via the DSI connector of the raspberry Pi 4?
I understand it uses the GPIO as a parallel interface by design, but as I need the GPIO I was hoping someone had documented some luck with custom connector /adapter and driver. It seems a bit limiting to not be able to use any other GPIO functionality if you choose to use this display…
Many thanks
