Hyperpixel 4 Virtual Keyboard?
Hi
Just got the Hyperpixel 4 Touch Display for my Pi3. Working well. Has anyone come across a virtual touch display keyboard driver for this display rather than using an attached USB keyboard?
Regards
Phil.
I recall there being a virtual keyboard for Raspian that people had used with the 7" touch display… not sure how well it would work on the Hyperpixel though since it’s quite a bit smaller.
If you want to try it supposedly you just have to:
sudo apt-get install matchbox-keyboard
Let us know how it goes - I would love to see some screenshots!
I should mention… I got that info from this thread on the official rpi forum, there’s some follow up discussion that may be useful for you.
https://www.raspberrypi.org/forums/viewtopic.php?t=14719
Hello Andy,
Thanks for your advice. Will download and post some screenshots.
Regards
Phil
Hello Andy,
Got the virtual keyboard to work. Need to get it to autoload, but will do that later.
See screen shot, it is useable.
Hi Phil,
I found that xvkbd was a little easier to use on this screen, especially in the “compact” mode without the numpad and F keys.
to install:
sudo apt-get install xvkbd
and to have it autostart,
you can use:
nano /home/pi/.config/lxsession/LXDE-pi/autostart
and add the following as the last line of the file:
@xvkbd -modal -compact
