My Pi 5 NVMe build
The Pi 5 is in a Pibow Coupe Ninja case. The NVME Base is in some left over Pibow layers. The bottom is from a Pi 4 Coupe case, then some expansion layers, and a Ninja Diffuser on top.
A Pico Nano links the two together so the ribbon cable doesn’t get damaged. It was just luck that the holes lined up like they did. At some point I’ll likely cut a one piece bottom layed out of a sheet of black diffuser I have.
