Octocam Mounting SD Card
I’m a total Newbie and hope you can help. How to I mount the SD card as a drive called boot so that I can drop the file wpa_supplicant.conf onto it?
I’ve built the image onto the SD using Etcher and using Windows 10.
Thanks in advance.
I just had to do this yesterday. Once you’ve burnt the image onto the SD card just remove it and pop it back into the PC. All you have to do is find the SD card from ‘This PC’ and you should be able to drop the file in. For me it wasn’t called ‘boot’ it just showed up as my D: drive (or whatever drive it was when you imaged it).
Thanks. That worked a treat and my octocam is now working and looking out of the front window :)
