After carefully soldering the pins for my Phat Dac and following the installation instructions from Pimoroni, I find that I cannot open my Chromium Web Browser. I can open the net from the command line but that is not very practical. Even with the Phat Dac removed from my Raspberry pi 3+, the problem still persists. Any advice most welcome and gratefully received. Mick Phillips
I’m not the most experienced with this, but here’s some thoughts.
It’s hard to think of how a few pins might impact something so specific in the software as launching a browser. Can you install a test OS different SD Card and see if you have any problems
Moving past #1, I’d wonder if there were any connected pins in your solder job that would be sending a signal to the Pi that would cause that problem. Can you post a close up photo of the board, specifically the solder work?
Thanks for taking the time to post a reply to my Phatdac problem. Your first suggestion turns out to be correct, as I decided to load a new OS a day or two ago. All systems are now go. Again, thank you for your response and best wishes.
