Hi (first post) - I have a recently purchased, from pimoroni, a Pi5 with NVME base and active cooler and I’m looking for an appropriately sized case on the shop, but none is apparent. Are any in plan? Or should I look elsewhere?
+1 searching for the same , it seems no official solution.
Found this in posts :
https://www.printables.com/model/644063-raspberry-pi-5-case-designed-for-active-cooler-and
Or
https://www.printables.com/model/749737-raspberry-pi-5-pimoroni-nvme-base-case
Unfortunately I don’t own 3D printer. I’ll contact pimoroni sales to see if they have an answer. To be honest it’s rather disappointing that pimoroni can make/sell the nvme base but have no case solution. Almost as if they have no strategic planning 😉
There was mention of a new case being worked on in another thread, a while back. There was no mention on a time frame for when that might happen though.
I was lucky in that I had an assortment of Pibow expansion layers and some unused cases. I bodged together what I hope they build with the bits and pieces I had on hand. Maybe if they see this it will give them a nudge. ;)
Here is a summary of an email I received from Pi Roon regarding the availability of an appropriate case:
Pimoroni are looking into case options to accommodate the NVMe base although Chinese New Year has slowed down prototypes a bit. The should also have some longer PCIe cables available to make using the NVMe base with existing cases easier
Just noticed that my spellchecker changed Pimoroni to “Pi Roon"!
The response was from Pimoroni.
I use the NVMe base and official pi5 case, but have the base as a hat, still plenty of room for the active cooler to work, mine is on 24/7 as a mini plex server.
I did a thread in Jan with pics:
I saw you don’t have a 3D printer but for those who do, I worked up a case for mine.
https://makerworld.com/en/models/437019
As a new user I can only post a single image. This one may be more important since it shows the 40mm fan pocket. You don’t see the NVMe drive but it’s there. Riding below the Pi it raises it up and needs a case that accommodates it.
I used a BambuLab printer that supports automatic filament changes is how I did the logo and text on the lid but it can be printed in a single color.
The active cooler is nice but doesn’t really reach down to cool the NVMe drive so I added the 40mm fan cubby to get cross ventilation over the drive. The .stl files are at the link.
Ordered the following and it fits for the PI5, official active cooler and the Pimoroni nvme base (bottom mounted) with a Samsung 970 EVO Plus nvme ssd.
The Geekworm P580 Case (make sure you have the P580 version!)
GeeekPi Raspberry Pi 5 PCIe to M2 NVME Card Installation Tool 64pcs/lot M2.5 Series Hex Brass Spacer + Screw Set Accessories Kit for Raspberry Pi 5:
@pabb, it seems you replaced the standoffs that comes with the NVME base. What’s the size of the standoffs you used? Did you remove the Rubber feet as well?
I just followed pabb’s advice and was able to use the P580-V2 case (well actually I ordered the V2 but the sticker on the box said V3).
The Geekworm wiki page (P580 - Geekworm Wiki) for the P580 has details of the standoffs in the FAQ section (you have to click “Expand” on this section: “Q: Does the P580 case support the pimoroni base nvme shield and 3rd party pcie bottom hats?”).
The standoffs I ordered were “M2.5x4mm+5mm Male-Female Brass”. The female part is 4mm deep and the male part is 5mm long.
Hope this helps you and/or others who come across this thread.
