I’ve received the new kit Picade 10-inch Display Upgrade Kit and I have a problem: The image on the screen is inverted. Has it happened to someone?
Adding this line to my config.txt fixed my inverted upside/down image on my 10" screen
display_rotate=0x10002
Oh, it works, thank you very much. But, why is this problem due? Is it a faulty screen?
There seems to be a batch of the controller boards out there at the moment that are doing this. It may be down to the firmware on them which I believe is outside of Pimoroni’s control.
Good thing it’s fixable with a setting 👍🏻
Not completely fixable, if you try to use a mouse on a desktop the X axis is inverted and the pointer is way off making it impossible to use at all. I can’t figure a work around other than get a replacement board
Apparently a lot of Replacement boards then 😞
