I bought a picade console and built it yesterday.
Everything seems ok, retropie is booting, but when I try to enter the command line in the terminal to install the software I get an error :
curl https://get.pimoroni.com/picadehat | bash
curl: (60) SSL certificate problem: certificate has expired
Exploring curl’s options I tried to launch the same bypassing SSL verification by adding --insecure option in above command
Seems to work at first, I get the prompt asking to execute despite the risk, then it seems ok :
Checking environment…
Updating apt indexes…
but then I get the following error :
E: The repository ‘https://packagecloud.io/kintaro/pcb/raspbian stretch Release’ does no longer have a Release file
Apt failed to update indexes!
So no joystick or buttons working although I can still continue to use my wireless 8bitdo gamepad, but that’s of course not the initial purpose of buying a picade console :-)
I don’t know how to resolve this, I assume the installer should be updated with another source, but I have absolutely no idea what to do…
I also bought a 10" screen picade that I will build today, I suppose I will get the same issue when trying to install software…
If anyone could help me, thanks in advance !
Nicolas
