Each time I boot the picade I am asked to map the buttons & keys. I go through all buttons and once at the end “OK” is highlighted, but no matter what button I push it doesn’t save or go to the next step.
I can only go to F4 and enter cli.
I have updated retropie last night, and stil the same issue.
I can’t find the file to map the keys manually.
Strangely enough, when I push the buttons on the picade one button registers as “Esc”, another as “Alt”.
Regardless, ENTER doesn’t work when I get to the OK step.
Any help would be greatly appreciated!
My picade’s specs:
pi 4 model B Rev 1.1
USB connected Device 001 Linux Foundation 3.0 root hub
device 003 Primax keyboard
device 002 VIA Labs, Inc HUB
device 001 Linux Foundation 2.0 root hub
bluetoothctl devices: none
Retropie version: 4.8.2, Last commit 1 year and 4 months ago (9dc632ae)
System rpi4 (armu71)running on raspbian Linux 10 buster
Below is boot/confg.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
overscan_scale=1
dtoverlay=picade
dtparam=audio=off
