New Picade Joystick and Buttons do not work
This is my second Picade. I was able to get the first edition working with little problems. However, I’m having a few big problems with the new one.
First, none of the buttons or joystick works. After connecting everything I typed in the command curl -sS https://get.pimoroni.com/picadehat | bash But I couldn’t type the | symbol. Does that make a difference?
I reconnected all the buttons, joystick, but still nothing works. I have the right power supply and a working version of retropie. I double checked all the connections!
My power button will turn on my picade but it doesn’t turn it off.
No sound
I’ve been following this thread PICADE - X Hat- Buttons + Joystick not detecting
but it hasn’t helped me fix any of my problems.
The fact that you can’t type the | symbol will absolutely cause problems! It means that the software install won’t work and everything that you describe - no controls, no power down, no sound.
You’ll need to find a way to type the one line install with the | symbol.
Do you know how to use SSH?
I have the same no | pipe symbol problem on my keyboard with the default UK layout in Raspbian. Once I switch to English US its where it should be. Doing a copy past while SSH’d in will work as far as I know.
I don’t know how you change keyboard layout in Picade?
Once I used raspi-config and changed the keyboard to a generic US keyboard it worked!!!
Thanks!!!
Glad to hear it was that easy.
I am using a US keyboard and to get the pipe symbol I use ALT + ~
Where the ~ key is the top right key next to ‘1’
And the ALT is the right-hand ALT key.
