Picade Max Power Hat Documentation
Hi there,
I got a Picade Max (PI 5 + NVME + Recalbox) that is awesome, and today I need to extend it’s feature.
I need to create a dual boot that I got working almost fine but setting one system or other is almost pain (need do connect keyboard, press space, then on the boot menu, select boot from USB) but got some ideas to be able to simplify process.
Anyway for this I would like to have documentation on PicadeMax Power Hat shield that is delivered with picade max. Shield has text printed on http://pimoroni.com/picademaxpower but link does not exist.
I did not find any documentation on it, especially on JST connector present on the hat (and other stuff) Any idea where can I can find any documentation? BTW what do we do if board fails, looks like it almost impossible to order a new one?
Thank you for your help
Regards
Is this what you are referring too?
If yes there is a schematic here.
On that board the JST Plasma header is for the following
You could also use it for case lighting with a RGB LED strip.
Thanks for the quick reply
Nope I was talking from this one
OK, I had a feeling that might be the case. I did a search with the “include retired” box ticked but it didn’t show up on the Shop Page. I was pretty sure there was an earlier Picade.
That JST is a Qwiic connector. i2c stuff, Breakout garden etc.
I “think” this might be relevant.
Other than that you can contact Pimoroni Tech Support via e-mail.
