Picade plasma buttons
I have a set of Plasma buttons but I just can’t get them to work at all. I put together a Picade with a PI5 and almost everything FINALLY works after a lot of tinkering. But the lights refuse to work.
The one line installer does not work. So I searched the forums and came across this method:
git clone -b master https://github.com/pimoroni/plasma-python.git`
cd plasma-python/
sudo ./install.sh`
That did install, but nothing happens. The buttons are still off (and yes, they are wired correctly).
When I try to run one of the examples manually I got the following error:
File “/home/admin/plasma-python/examples/rainbow.py”, line 6, in
from plasma import auto
ModuleNotFoundError: No module named ‘plasma’
So, I discovered that if I put “source /home/admin/Pimoroni/auto_venv.sh” in the bashrc file I can manually start an example py file to make the LEDs work. Obviously, I would need to do that manually every time, so that’s not much of an option, but I’ve at least confirmed that the leds all work and that everything is wired properly.
Hopefully someone can help me automate all this
