Hi! Just finished building my Picade and have installed my first game…;). Everything was going swimmingly, but the audio is giving me issues. The volume is too low at 100%…I’m using the correct powersupply…any ideas? Also, where can I find what buttons do what on the 5 button screen control board?
the ‘buttons’ terminal are generic in the sense that they can be customised in the firmware if you want to and you need bind them from within Emulation Station, RetroArch, or by modifying individual emulators configs.
Hi RougeM, thanks for the response. I currently assess the volume using the
menu dialog that comes up in Emulation Station.
There was some behaviour change somewhere…the volume was initially fine
but after a software update and installing all the retropie stuff the
volume is seriously lacking…I’m not that linux savvy, but I have the
capability of uploading arduino programs etc…
have you tried using the volume buttons on the Picade itself, they do control the volume going out to the speakers (proportionally to the level entering the board via Audio IN jack).
… and if that still does not work, try to exit RetroPie and at the command line run alsamixer to verify the output from the Pi is as high as it can be.
Thanks, I have verified that the Pi is outputting 100% from one of the
system menus…any reason why the volume controls on the Picade weren’t
brought out to the case in some way or have I missed something very basic
here (highly likely! ;-).
