Piglow supported on Raspberry Pi 3 B?
My Pi 2 B gave up the ghost and I ordered a Pi 3 B.
Will my Piglow work in the 3 B?
Absolutely!
You might need to adjust timings in your code, although it’s less pronounced from the 2 to the 3, the speed bump will make some things noticeably faster depending on how you handle timing/delays.
My scripts don’t seem to work with the RPI 3B.
I was using shell scripts to call the piglow executable.
I don’t see any light activity and don’t get any error messages.
#!/bin/bash
1by1 - Start each leg from the center, one by one.
trap “piglow all 0;exit” SIGINT SIGTERM
piglow all 0
while true;do
for i in 0 1 2;do
for j in 5 4 3 2 1 0;do
piglow led $i $j 1
sleep .5
done
done
sleep 1
piglow all 0
done
Is i2c enabled on your Pi? What do you see when you ls /dev/i2c-*?
Also see the notes at the bottom of this page: http://wiringpi.com/dev-lib/piglow/
Thanks! The piglow c program in the wiringPi package was what I needed! After compiling it, my PiGlow is glowing with my scripts again! I had saved a tar file of my scripts, but didn’t make note of where the piglow executable came from.
