Little more info below, I haven’t done anything here just a fresh install. If there is something else I could toss out there to help troubleshoot please let me know. I’m semi new to all this.
pi@pizeromusicplayer:~ $ sudo systemctl status mopidy
● mopidy.service - Mopidy music server
Loaded: loaded (/lib/systemd/system/mopidy.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2020-09-29 15:41:34 BST; 3min 22s ago
Process: 475 ExecStartPre=/bin/mkdir -p /var/cache/mopidy (code=exited, status=0/SUCCESS)
Process: 479 ExecStartPre=/bin/chown mopidy:audio /var/cache/mopidy (code=exited, status=0/SUCCESS)
Main PID: 480 (mopidy)
CGroup: /system.slice/mopidy.service
└─480 /usr/bin/python3 /usr/bin/mopidy --config /usr/share/mopidy/conf.d:/etc/mopidy/mopidy.conf
Sep 29 15:42:12 pizeromusicplayer mopidy[480]: INFO [MainThread] mopidy.commands Starting Mopidy frontends: RaspberryGPIOFrontend, PiDiFrontend, IrisFrontend, HttpFronte
Sep 29 15:42:12 pizeromusicplayer mopidy[480]: INFO [IrisFrontend-9] mopidy_iris.core Starting Iris 3.52.4
Sep 29 15:42:12 pizeromusicplayer mopidy[480]: INFO [HttpFrontend-11] mopidy.http.actor HTTP server running at [::ffff:0.0.0.0]:6680
Sep 29 15:42:12 pizeromusicplayer mopidy[480]: INFO [MainThread] mopidy.commands Starting GLib mainloop
Sep 29 15:44:49 pizeromusicplayer mopidy[480]: WARNING [FileBackend-3] mopidy.file.library Failed looking up file:
mopidy.conf
pi@pizeromusicplayer:~ $ sudo cat /etc/mopidy/mopidy.conf
# For information about configuration values that can be set in this file see:
# https://docs.mopidy.com/en/latest/config/
# Run `sudo mopidyctl config` to see the current effective config, based on
# both defaults and this configuration file.
[raspberry-gpio]
enabled = true
bcm5 = play_pause,active_low,250
bcm6 = volume_down,active_low,250
bcm16 = next,active_low,250
bcm20 = volume_up,active_low,250
bcm24 = volume_up,active_low,250
[file]
enabled = true
media_dirs = /home/pi/Music
show_dotfiles = false
excluded_file_extensions =
.directory
.html
.jpeg
.jpg
.log
.nfo
.pdf
.png
.txt
.zip
follow_symlinks = false
metadata_timeout = 1000
[pidi]
enabled = true
display = st7789
rotation = 90
[mpd]
hostname = 0.0.0.0
[http]
hostname = 0.0.0.0
[audio]
mixer_volume = 40
output = alsasink device=hw:sndrpihifiberry
[spotify]
enabled = false
username =
password =
client_id =
client_secret =
pi@pizeromusicplayer:~ $ sudo mopidyctl config
Running "/usr/bin/mopidy --config /usr/share/mopidy/conf.d:/etc/mopidy/mopidy.conf config" as user mopidy
WARNING [MainThread] mopidy.config Ignoring config section 'mpd' because no matching extension was found
[core]
cache_dir = /var/cache/mopidy
config_dir = /etc/mopidy
data_dir = /var/lib/mopidy
max_tracklist_length = 10000
restore_state = false
[logging]
verbosity = 0
format = %(levelname)-8s [%(threadName)s] %(name)s %(message)s
color = false
config_file =
[audio]
mixer = software
mixer_volume = 40
buffer_time =
[proxy]
scheme =
hostname =
port =
username =
password =
[raspberry-gpio]
enabled = true
bcm0 =
bcm1 =
bcm2 =
bcm3 =
bcm4 =
bcm5 = play_pause,active_low,250,
bcm6 = volume_down,active_low,250,
bcm7 =
bcm8 =
bcm9 =
bcm10 =
bcm11 =
bcm12 =
bcm13 =
bcm14 =
bcm15 =
bcm16 = next,active_low,250,
bcm17 =
bcm18 =
bcm19 =
bcm20 = volume_up,active_low,250,
bcm21 =
bcm22 =
bcm23 =
bcm24 = volume_up,active_low,250,
bcm25 =
bcm26 =
bcm27 =
[pidi]
enabled = true
display = st7789
rotation = 90
[iris]
enabled = true
country = NZ
locale = en_NZ
spotify_authorization_url = https://jamesbarnsley.co.nz/iris/auth_spotify.php
lastfm_authorization_url = https://jamesbarnsley.co.nz/iris/auth_lastfm.php
genius_authorization_url = https://jamesbarnsley.co.nz/iris/auth_genius.php
data_dir = $XDG_DATA_DIR/iris
[file]
enabled = true
media_dirs =
/home/pi/Music
.directory
.html
.jpeg
.jpg
.log
.nfo
.pdf
.png
.txt
.zip
[http]
enabled = true
hostname = 0.0.0.0
port = 6680
zeroconf = Mopidy HTTP server on $hostname
allowed_origins =
csrf_protection = true
default_app = mopidy
[m3u]
enabled = true
base_dir =
default_encoding = latin-1
default_extension = .m3u8
playlists_dir =
[softwaremixer]
enabled = true
[stream]
enabled = true
protocols =
http
https
mms
rtmp
rtmps
rtsp
metadata_blacklist =
timeout = 5000
[spotify]
enabled = false ; Extension disabled by user config.
mopidy deps
pi@pizeromusicplayer:~ $ mopidy deps
Executable: /usr/bin/mopidy
Platform: Linux-5.4.51+-armv6l-with-debian-10.4
Python: CPython 3.7.3 from /usr/lib/python3.7
Mopidy: 3.0.2 from /usr/lib/python3/dist-packages
Mopidy-Spotify: 4.0.1 from /usr/lib/python3/dist-packages
mopidy-pidi: 1.0.3 from /usr/local/lib/python3.7/dist-packages
Pykka: 2.0.2 from /usr/lib/python3/dist-packages
musicbrainzngs: 0.7.1 from /usr/local/lib/python3.7/dist-packages
netifaces: 0.10.9 from /usr/local/lib/python3.7/dist-packages
setuptools: 40.8.0 from /usr/lib/python3/dist-packages
Mopidy-Iris: 3.52.4 from /usr/local/lib/python3.7/dist-packages
mopidy-raspberry-gpio: 1.0.2 from /usr/local/lib/python3.7/dist-packages
GStreamer: 1.14.4.0 from /usr/lib/python3/dist-packages/gi
Detailed information:
Python wrapper: python-gi 3.30.4
Relevant elements:
Found:
uridecodebin
souphttpsrc
appsrc
alsasink
osssink
oss4sink
pulsesink
id3demux
id3v2mux
lamemp3enc
mpegaudioparse
mpg123audiodec
vorbisdec
vorbisenc
vorbisparse
oggdemux
oggmux
oggparse
flacdec
flacparse
shout2send
Not found:
flump3dec
mad
