Hey there, just built my picade, and love it… when it works.
I have a few gripes about the button quality. But first and foremost, my volume up and down controls don’t seem to be working. Maybe the picade board is to blame?
running retropie retropie-v3.8.1-rpi2_rpi3
configuring controls, vol up and down do not respond
checked and rechecked wiring and connections, everything is secure
swapped out buttons with 1,2,3,4,5,6 buttons, still not working (does not light up on the picade board when pressed)
is there anything i can do? I just bought this a week ago from AdaFruit.com, I figure you guys would be better suited for help/repair.
Do you get any sounds at all? When i built my picade I had no sounds. I had to go into the RetroPie menu and then Audio to change the sounds to do Headphones 3.5 mm jack. That worked for me.
It’s possible this could be related to other issues we’ve seen with the audio input connector coming loose from the board, Could you possible post a photo of your setup, paying particular care to the audio input?
