Hi, recently built the Picade received for Xmas. Brilliant piece of kit but having issues with the zippy joystick.
Both axes work well enough but having problems with ↖️↙️ . Taking off the control panel again and looking behind the joystick whilst moving it it appears that it is not hitting both switches at the same time.
Moving in the diagonals ↗️↘️ I can hear both microswitches being engaged with two distinct clicks. On the opposite diagonals i can only hear 1.
Any suggestions how this can be fixed? (If at all possible??)
I had the same problem with down/left and up/left. The Joystick has a restricor plate at the bottom to set it into 2-way, 4-way or 8-way mode. I simply removed this plate and now all eight directions work like a charm. Hope this helps.
No Problem. Just to set this right: my joystick was set to 8-way by this restrictor and should have worked but only removal of the plate did the trick. I think the restrictor is crap, might be useful if you only play Pac Man or Space Invaders …
I’ll probably still get a Sanwa/Siemitsu just because the travel seems a bit longer. Not having much luck getting zangief’s spinning pile driver (requires a quick 360 input).
Spot on for me too! The 8 way setting doesn’t seem to align properly so causes the issue. Strangely enough just removing the top plate didn’t work but I noticed the green plate underneath had a loose screw as well. Tightened that up and it’s perfect
