Hi Guys! first post to be kind ;)
I have been playing around with trying to finally get everything working with the PiCade ( i was one of the original PiCade backers).
I have managed to get sound working with the screen volume control by doing this:
- Enable all audio via the 3.5mm jack from the PI
- Send the output from the 3.5mm jack to the “PC Audio In” input on the display board (mine is a “M.NT68676.2A” - manual is here : http://www.vslcd.com/Specification/M.NT68676.2A.pdf)
- Send the output from the “earphone out” on the display board to the “line in” on the display board.
See this image:
This seems to work ok but my only question is - Is there a way that if I send the PI audio to the HDMI port that the “M.NT68676.2A” display board can then send it to the output of the “earphone out” directly ?
The “M.NT68676.2A” seem to be fairly common and also seem to have some kind of factory menu / firmware config/upgrade so I wondered if this was something I could enable. Any ideas?
Thanks in advance!
Mark
