I got a Black Hat Hack3r to use for my project and it looks amazing
Though I am having big problems with it:
when the Hack3r is attached the Raspberry pi doesn’t turn on at all, which as you understand is kind of a big deal.
To connect the Hack3r and the Raspberry pi I am using the same configuration as the one shown in this page https://shop.pimoroni.com/products/black-hat-hacker.
I don’t really know where to go from here and any help would be highly appreciated.
all the best,
Luisa
PS:
I want to use the Hack3r to work with a Raspberry pi B 1.0 and to attach to
First of all: thank you all so much for answering me!
I tried to run the code RogueM suggested, this is the result:
Hardware Revision : a01041Revision match: Pi 2 Model B Rev 1.1Linux raspberrypi 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/Linux
Here you can see pictures of the setup and of the soldering, maybe you can see something I can’t.
I can’t see anything wrong with your setup. However you will not be able to use the black hat hacker with the hats/phats you said as they share some pins.(pin25 & 24) however if they are not connected I an sure why the pi won’t boot.
Finally check your using an up to date operating system although that shouldn’t matter as the pi shouldn’t take notice of it at boot
No, I’m talking about the plane: pin 1, carrying 5v and pin 2, carrying 3.3v run side by side. On close-up, there is what seems to be exposed copper between the pin headers further away from the Pi.
