Bricked Enviro Urban
I configured a new Urban Enviro, but after not getting any logs etc , and several restarts for config.
Eventually I ended up with the error light. So I went for the nuclear reflashing option a couple of times, but still the getting the error light. So I am running out of ideas
More info on what that is, what you did might help. ;)
Was it this perhaps?
And what uf2 is it now flashed with?
Is it the Warn LED that’s lit up?
  • The Warn LED is connected to the RTC, so it can be lit even during deep sleep to notify you of problems. It is limited to three states - on, off, or 1hz blink (it’s not possible to control the brightness).
Or > If you haven’t already configured this board then it will automatically switch into provisioning (setup) mode - you can tell this has happened if the ACTIVITY LED starts to blink rapidly.
enviro/documentation/getting-started.md at main · pimoroni/enviro
Thanks for your response.
After more fiddling last night I fixed it by nuking it again and then reapplying the other build over the top it came to life.
