Thanks for the help. I tried what you suggested and got a a message that I needed to fun it as root
`pi@raspberrypi:~/flotilla-pre/raspi/> firmware $ ./update_firmware
Install must be run as root. Try ‘sudo ./’`
So I tried it with sudo anf got an error message saying I need to force it
`pi@raspberrypi:~/flotilla-pre/raspi/firmware $ sudo ./update_firmware
Flotilla Firmware Updater
dock firmware file found
ImportError: No module named flotilla
The flotilla Python API is not installed.
This is not essential to update the firmware
but should you wish to you can install it using:
\curl -sS get.pimoroni.com/flotilla | bash
Plug in your Flotilla Dock now.
Updating should continue automatically.
Bus 001 Device 006: ID 03eb:2fe4 Atmel Corp. ATxmega32A4U DFU bootloader
Erasing flash… Success
The target memory for the program is not blank.
Use --force flag to override this error check.
Dock Firmware Update completed
Please unplug/replug your Flotilla Dock before use!`
So I tries it with --force and still got errors
`pi@raspberrypi:~/flotilla-pre/raspi/firmware $ sudo ./update_firmware --force
Checking memory from 0x0 to 0x7FFF… ERROR.
I’m not sure what to do from here.
