I can’t get the GrowHat screen to work, likely because of a missing module.
When running:
python monitor.py
I get:
File “/home/jmcmillon/Pimoroni/growhat/examples/monitor.py”, line 10, in
import ltr559
ModuleNotFoundError: No module named ‘ltr559’
pip install ltr559
Throws the following error:
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
Bookworm has changed how Python modules need installed. You can find more information about how to work with it or around it in this thread: St7789 install error with Bookworm?
Pimoroni needs to update its GrowHat instructions at
and its code referenced by curl -sSL https://get.pimoroni.com/grow | bash
to either make their code work under bookworm,
or to warn users to use previous bullseye instead.
The new Python Virtual Environment is (for me anyway) a PITA. At the moment I’m running Legacy on anything that isn’t a Pi 5. It just makes life easier on this old brain.
Pimoroni is playing catchup in terms of installers and instructions etc.
