Hi Guys,
I just got my picade console and it definitively looks great.
I built it up using the video instructions and it went smooth through :-)
I installed now Retropie 3.5 on an SD Card and try to run it using the Picade console. Here I’m facing some issues :-(
As many of use posted to confirm that it works like a charm, I tough you may give me some tips :-)
Basically at first boot the console is not recognized by Retropie. So holding one button makes it discovered as a keyboard. At that point I can configure the key mapping through the UI which works fine.
Once in EmuleStation the buttons and the stick work properly. The issue come when I start a ROM where the pad and buttons are not recognized anymore…
Looking to /tmp/runcommand.log shows the following:
Core: Country: Europe (0x50)
UI-Console Status: Cheat codes disabled.
UI-Console: using Video plugin: ‘Mupen64Plus OpenGL Video Plugin by Rice’ v2.0.0
UI-Console: using Audio plugin: ‘Mupen64Plus OMX Audio Plugin’ v2.0.0
Input Error: Couldn’t find config file 'InputAutoCfg.ini’
Input Warning: missing ‘plugged’ parameter from config section AutoConfig0. Setting to 1 (true).
Input Warning: missing ‘plugin’ parameter from config section AutoConfig0. Setting to 1 (none).
Input Warning: missing config key ‘DPad R’ for controller 1 button 0
Input Warning: missing config key ‘DPad L’ for controller 1 button 1
Input Warning: missing config key ‘DPad D’ for controller 1 button 2
Input Warning: missing config key ‘DPad U’ for controller 1 button 3
Input Warning: missing config key ‘Start’ for controller 1 button 4
Input Warning: missing config key ‘Z Trig’ for controller 1 button 5
Input Warning: missing config key ‘B Button’ for controller 1 button 6
Input Warning: missing config key ‘A Button’ for controller 1 button 7
Input Warning: missing config key ‘C Button R’ for controller 1 button 8
Input Warning: missing config key ‘C Button L’ for controller 1 button 9
Input Warning: missing config key ‘C Button D’ for controller 1 button 10
Input Warning: missing config key ‘C Button U’ for controller 1 button 11
Input Warning: missing config key ‘R Trig’ for controller 1 button 12
Input Warning: missing config key ‘L Trig’ for controller 1 button 13
Input Warning: missing config key ‘Mempak switch’ for controller 1 button 14
Input Warning: missing config key ‘Rumblepak switch’ for controller 1 button 15
Input Warning: missing config key ‘X Axis’ for controller 1 axis 0
Input Warning: missing config key ‘Y Axis’ for controller 1 axis 1
I tested with a standard keyboard in USB on the Pi and it works fine.
So did I miss something or is there any issue between the PCB and retropie 3.5?
Thanks a lot for any advice.
Kaz
