Pi 4 stopped booting
Pi 4 arrived on Monday, inserted an SD card that I’d prepared earlier (cloned from Pi 3 and upgraded to Buster) and the Pi 4 booted first time. It was running great for a couple of days, but got home today to it being unresponsive.
Cycled power, still no working system. Removed the SD card and put it back in the Pi 3 and it booted fine.
Put the SD card in the PI 4, no boot. Unfortunately I don’t yet have a micro HDMI adapter to see what’s happening. I’m using an official Pi 4 power supply, but also tried another USB-C power adapter.
Any thoughts?
In spite of the SD card having formerly worked and still working in a Pi 3 I’d still suggest trying another SD card with a fresh install of the latest OS.
It’s the simplest way to start to faultfind.
Thanks - I just flashed the latest raspian buster image to a spare SD card, and it still doesn’t seem to boot. Both orange/yellow LEDs stay lit constantly.
I added wpa_supplicant.conf to /boot and the Pi doesn’t appear on the LAN. Checking /var/log/syslog on the sd card shows no sign of a successful boot.
Any other thoughts? I won’t have a micro hdmi adapter until Monday or Tuesday (depends how quick Amazon AU are :P)
I’m out of simple ideas.
Wait for more experts to chime in :-)
Anything else plugged into that Pi 4B?
Nope, no peripherals at all.
I presume you are using an official Raspberry Pi 4 USB-C power supply?
Hi neilman, yes sure am.
Some more testing:
At this stage, I think this is dead :(
If you have a voltmeter check the +5V and 3.3v pins on the GPIO. I’m thinking you likely don’t have any 3.3V anymore. For what ever reason the voltage regulator has failed.
I checked the 3.3v GPIO pin and it’s only around 2 volts - which can’t be good :)
Oh dear, it is looking like it is an ex-Pi4, bereft of 3.3v it cannot boot or do anything.
That’s not good news is it?
Wonder what killed it?
G’day Neil,
No idea - it was in a Flirc case, with only a USB Hub (for USB zwave controller) and the official power supply plugged in.
I’m assuming a hardware failure - I’ve emailed pimoroni support for advice.
Cheers,
Paul
Ive had several similar issues with PI4’s
HOWEVER I have to admit none of them were from an actual HW failure.
Someone on another board suggested using a HIGH ENDURANCE SD card made for VIDEO, so I bought one and haven’t had any issues.
Like you it was VERY strange, it worked for a week straight and NO Issues. Then I rebooted it one day and BOOM no more boot and worse yet, only 1 of the LEDs would light (Im color blind so don’t know which one).
THEN on another one I had a POWERED USB3 hub plugged in with 4 USB3 HD’s. One of the HD’s was stopping it from booting. I unplugged them one at a time and found the one and as long as I remember to unplug that one when I reboot I have no issue.
I have the same problem, my microsd card does not boot after first confi in pi 4. But, if I insert the microsd in pi 3, it boots and after pi 3 boot, I reinsert in pi 4, it boots.
