Is it OK to use the full size Breakout Garden with the Pi Zero W?
Anything to look out for?
I haven’t tried it but I can’t think of a reason it wouldn’t work.
Pi Zero’s will work with full sized hats. That Hat should be compatible with any Pi that uses a 40 pin GPIO Header. You may have to put some tall standoffs in the two farthest corners to get it level, but other than that, have fun.
Fabulous, thank you very much!
