I have the following and it works.
import network
wlan.active(True)
print(wlan.scan())
The output isn’t the best though. Was wondering if anybody has something better and more refined? Something that gives a nice list format like the Pico Wireless example.
import picowireless
picowireless.init()
picowireless.start_scan_networks()
networks = picowireless.get_scan_networks()
print("Found {} network(s)...".format(networks))
for network in range(networks):
ssid = picowireless.get_ssid_networks(network)
print("{}: {}".format(network, ssid))
print("\n")
time.sleep(10)
scan() returns a tuple - (ssid, bssid, channel, RSSI, security, hidden) so you can do something like:
import network
wlan.active(True)
networks = wlan.scan()
print("{} networks found:\n".format(len(networks)))
print ("{:<64} {:<8} {:<6})".format('ssid', 'channel', 'rssi'))
for net in networks:
print ("{:<64} {:<8} {:<6}".format(net[0].decode(), net[2], net[3]))
Andy
Thanks for that, will give it a go sometime tomorrow. In chill out mode at the moment, its just about 9 PM here. I’m self taught Python and Micro Python wise. I can usually tell what a block of code does, just not how it does it. ;)
Welcome aboard the Pimoroni Forums. =)
No worries… hopefully you can get why you need. BTW should have said scan() returns a list of tuples
I’ve done a fair bit of Python programming but new to MicroPython - finding the documentation a bit patchy but getting good at digging through GitHub!
Andy
Just gave it a try.
>>> %Run -c $EDITOR_CONTENT
5 networks found:
ssid channel rssi )
BELLALIANT568 1 -95
alphanumeric 6 -52
BELL815 4 -69
BELL003 9 -76
Brandan-2g_EXT 11 -94
