I had a look when i first received mine, but there wasn’t a zero w compatible image, however you can install Mopidy which pimusicbox is based on, then the web extension Mopidy-MusicBox-Webclient that is used by Pimusicbox. If you install the pimoroni dashboard and use it to install the phat, the audio should work out of the box, if you sudo usermod -a -G i2c mpd the vumeter should work, and a plugin Mopidy-TtsGpio configured with the correct gpio pins should also get the buttons working as long as you configure a pin_play_led to an unused gpio No sound from Pirate Radio after installing spotipy script
Related topics
| Topic | Replies | Views | Activity | |
| Trouble with Pirate Audio install | 7 | 1931 | April 26, 2020 | |
| Pirate Audio Amp/Software Setup Problems | 0 | 867 | November 29, 2019 | |
| Pirate Radio Phat Buttons Config | 5 | 949 | February 17, 2020 | |
| Pirate Audio 3w Amp + Pi Zero 2w - mopidy / Iris install not working | 3 | 230 | September 23, 2024 | |
| Pirate Audio without mopidy? | 11 | 2848 | May 21, 2020 |
