Yesterday I got my little Pirate Radio. It is now up and working as an internet radio. But I have a question/observation.
In all the documentation it refers to the playlist being in /home/pi/.config/vlc/playlist.m3u.
After the initial install this file did not exist, but there was a playlist active. I could not find the file holding this playlist to edit it. It was only when I put the playlist in /boot that the playlist under .config appeared.
Was I missing something, or does the documentation need updating?
Try sudo nano /etc/vlcd/default.m3u
Putting your own in /boot will replace the one I listed above with yours. On a clean install of pirate radio I believe its the one you want to edit.
My little Pirate Radio is now working happily. I have a playlist set up amd my wife and I can both control the channel it is playing through the vlc web interface.
So the next question is …
On the web interface you can see the ability to use the device as a media player. Can anyone tell me where it is expecting to see the audio files, or do I need a file similar to the playlist.3mu to point at the files, and what should it look like?
alphanumeric
The file /etc/vlcd/default.m3u is just the default file - used for only the initial install. Once you have a working system editing it makes no difference. So far the only way I have found of changing the playlist is putting a new version in /boot. I have been searching the file system for where the /boot version is moved, but without success.
OK, it was many moons ago when I tried to edit the one actually in use and add to it. Plus, I’ve only done it on the normal Pirate Radio curl Install. Lately I just put my small custom file in /boot and let it get copied to where ever it goes.
Yes - that is what I found. What I want to do is to upload music
to the radio, add it to the playlist, and reload the playlist
using the button on the html interface, without having to reboot
the radio.
loaded the latest v20180020 gets to the pirate pyhon info page asked to login the keyboard does not respond tried changing the log in details in setting not seeing the USB keyboard any ideas?
I have a bag full of TV and Cable remotes to play with. I don’t think it was the remote that was the issue. More likely “my code” used to make use of the remote ;)
load the install noobs program no problem all works mouse and keyboard … notice when the program loads on startup i get the prompt failed to load kernel module tried different SD card same problem using win 10 also format the SD card with the prescribed format program… any ideas?
I think you may get better help if you start your own thread. It sounds like your not using the PiratePython image.
Personally, I don’t use NOOBS. I get Raspbian here,
An use etcher to image it to my SD Card.
Then I follow this to install Pirate Radio
Hi - the issue with Buster in the Pirate Radio code is that it checks for the OS level in the VLC bringup and “buster” is not in the list so VLC loading fails. There are two ways to fix this, either run Stretch or change the config file for the VLC player and add a line to accept the new 'buster" OS.
