Raspberry pi won't boot
Help please my pi is showing red and green light only, I tried different hdmi cables as well as using the composite cable, when I plug in the memory card it came with in my Ubuntu 15.10 laptop to view the file it is not recognized as having an SD card inserted. When the card is inserted into an Android tablet it says to insert an SD card.
I would re-flash the SD with the very latest Raspbian.
I think the SD card I have is defective, would you suggest I just try another SD card and try to download all the Rasbian software?
That worked, thanks I reformatted a different SD card moved the files over to it and it was up and running. Thanks
