Trouble installing Pirate Radio software (Buster OS + Certificate)
Hello. I am a fairly good customer of Pimoroni products, for which I have so far a spotless experience (see my blog https://raspicolas.wordpress.com/) – until now.
I have purchased recently the Pirate Radio kit as a present for father’s day. After some troubles building it (the construction page is not fully clear – I had to reorder a pHat Beat card), I am now facing the challenge of installing the software package.
I have followed faithfully the instructions page but I am facing two serious issues:
  • The bash says that it cannot install vlc on latest PiOS Buster Lite version (dunno why)
  • I have tried installing Raspian Stretch Lite but when launching “curl https://get.pimoroni.com/vlcradio | bash” I get an “expired certificate” error (and curl -k solves only partly the problem)
Any hint ?
Note: Installing PiratePython works, but is too limited for my usage.
Thank you for any help.
I got it working after 2 days. You need to use the latest Raspberry Pi OS
Run the curl, after it is ‘finished’ do the steps that are described here
“elif cat /etc/os-release | grep -q “buster”; then
IS_SUPPORTED=true && IS_EXPERIMENTAL=false”
add the map “.config” to your pi home map, add “vlc” to your “.config” map.
Make the file playlist.m3u => sudo nano /home/pi/.config/vlc/playlist.m3u
Put your music-links in this file.
if you could tell me how to relaunch the whole vlc-radio without restarting, it would be nice.
I want to use the radio as an alarm radio, so I want to play music at 08.00 in the morning, but with working buttons and the flashing LEDs… I can’t figure out what exactly I need to put in my crontab…
Thanks SimonV. I’ll try the patch. These instructions should be included in the install page IMHO.
Note that I eventually managed to install it on Stretch, and I got it to work – not without some sweat… see here my story: https://raspicolas.wordpress.com/2020/06/28/assembling-pimoroni-pirate-radio-kit-the-good-the-bad-and-the-ugly/
-N.
you can get it installed with buster, forgot to tell you:
in stead of vlc vox, you need to install vlc-bin and vlc-plugin-base:
sudo apt-get install vlc-bin
sudo apt-get install vlc-plugin-base
then run the setup.sh (sudo bash setup.sh) after you added the rules with buster in the script
if you do that, all will work
After “sudo bash setup.sh” command I’ve got warning :
pi@raspberrypi:~/Pimoroni/phatbeat/projects/vlc-radio $ sudo bash setup.sh
— Warning —
The VLC Radio installer
does not work on this version of Raspbian.
Check GitHub: Where the world builds software · GitHub
for additional information and support
