Hi!
My zero w always shut down whenever I try to upgrade the os (rasbpian jessie 17/04…) I tried different SD cards and different power supplies on both my pis without success.
Any idea what causes these issues? The power supply provides up to 1.5 A. Do I need more?! I have never experienced anything like this with my pi 3 using the same power supply…
If you’ve recently re-formatted an SD card for use with your new Pi, did you remember to expand the filesystem in the raspi-config menu? If your SD card is over 8GB big, you may need to expand your system so that it can update.
The process just freezes completely, just like so:
26 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/79.0 MB of archives.
After this operation, 4,548 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Reading changelogs… Done
Preconfiguring packages …
(Reading database … 31473 files and directories currently installed.)
Preparing to unpack …/tzdata_2017b-0+deb8u1_all.deb …
Unpacking tzdata (2017b-0+deb8u1) over (2016j-0+deb8u1) …
And then it just freezes. Syslog give no info, you just see some arbitrary entry, and the next one would be info on starting up again (after I reconnect power). I had expanded my system to full capacity of 16 GB, 14 Gigs free…
[Update]
Okay, it seems to be the SD card. I monitored dmesg and eventually got this output:
[Jun29 22:33] mmcblk0: card_busy_detect: error sending status cmd, status 0x4080900
[ +0.000012] mmcblk0: retrying write for general error
[ +0.000302] mmcblk0: mmc_blk_err_check: general error sending stop command, stop cmd response 0x80d00
[ +0.000055] mmcblk0: retrying write for general error
[ +0.000256] mmcblk0: mmc_blk_err_check: general error sending stop command, stop cmd response 0x80d00
[ +0.000068] mmcblk0: retrying write for general error
[ +0.000263] mmcblk0: mmc_blk_err_check: general error sending stop command, stop cmd response 0x80d00
[ +0.000056] mmcblk0: retrying write for general error
[ +0.000252] mmcblk0: mmc_blk_err_check: general error sending stop command, stop cmd response 0x80d00
[ +0.000050] mmcblk0: retrying write for general error
[ +0.000278] mmcblk0: mmc_blk_err_check: general error sending stop command, stop cmd response 0x80d00
[ +0.000057] mmcblk0: retrying write for general error
[ +0.088883] mmcblk0: mmc_blk_err_check: general error sending stop command, stop cmd response 0x80d00
[ +0.000053] mmcblk0: retrying write for general error
[ +0.000038] blk_update_request: I/O error, dev mmcblk0, sector 2190712
[ +0.000020] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:314: I/O error -5 writing to inode 17444 (offset 0 size 4096 starting block 273840)
[ +0.000014] Buffer I/O error on device mmcblk0p2, logical block 262063
[ +10.185094] mmc0: timeout waiting for hardware interrupt.
[ +0.000023] [239a80f7] CMDD 8 200
[ +0.000009] [239a80f8] SDMA da43a0fc dac27e10
[ +0.000007] [239a80fa] FCM< da43a02c da43a094
[ +0.000006] [239a80fa] RSP 900 0
[ +0.000007] [239a80fb] FCM> da43a02c 0
[ +0.000007] [239a80fb] CMD 19 200
[ +0.000006] [239a80fb] REQ> da43a02c 0
So: please stay away from these here: Lexar 16GB microSDHC UHS-I LSDMI16GBB1EU300A
